How to hook a tach up to a mid 70s starflight 85 hp
jtexas
Re: How to hook a tach up to a mid 70s starflight 85 hp
if "mid-70s" is mid enough, this is the wiring scheme:
IGN = purple wire (keyswitch terminal "A")
GND = black wire (keyswitch terminal "M")
SND = gray wire from the wiring harness
Lt = gauge lighting, or running light switch, or purple wire
tach selector = 6p
evinrude bayliner
Can i hook up the tach lead wire to the negative side of one of the ignition coils? The reason i am asking is because I am unable to find a gray wire coming from the harness under the dash.
Lakester
hello,
ck for the gray wire coming off the engine electrics. my 71 schematic shows it for mine, both dash and engine... ur's no doubt, too.
regards,
lakester :cool:
evinrude bayliner
There is a gray wire on the harness at the engine but i have not found one under the dash. I should mention that the motor is not original to my boat and wires have been spliced in the past. The boat did not originally have a tach on it. I bought a tach to install on it and on the back of the tach gauge the wiring diagram says to hook up to the negative side of the coil. I would like to know if i can do this with my motor to keep from guessing underneath the dash what wires are what.
