How to hook Teleflex Rack cable to 1962 outboard
outonbizniz
I have a 1962 Evinrude 75HP outboard. The boat I own has a teleflex rack system. The outboard that was not sold with the boat had the tube type steering system. My motor does not. The cable on the teleflex system is siezed. I will be replacing it.<br />Question is how does the steering cable attach to the outboard? I know how it attaches to the transom.<br /><br />Here is a pic of the steering hook up that my outboard has. I have the bracket that the pulley cables would have attached to. Does the teleflex cable bolt through one of the holes on this bracket or do I need a different bracket? Does teleflex carry these?<br />
outonbizniz
Re: How to hook Teleflex Rack cable to 1962 outboard
I now know that what I'm looking for is a clevis adapter. Still don't have a source. Teleflex doesn't have them.
Lark40
The system shown in the ad is the old cable/pulley system. Have one my old boat. <br /><br />Many, many thousands of these have been converted to Teleflex-style systems over the years, so adapters were made.<br /><br />You might ask at older marinas, chances are that mechanics there may be able to find a new or used adapter for you.
rickdb1boat
outonbizniz <br /><br />Not sure exactly what your after, but try this link and look around a bit. Might have what you're after.<br /> <br /><br />boatingsolutions
Franki
Teleflex do make an adaptor.. just put one on my boat... (72 model motor, same situation.)<br /><br />I can find the part number if you like..<br /><br />cost me $80 AUD.. has a tube the cable fits into.. and a bracket on a ball joint that bolts to the transom with the tube locked into it..<br /><br />There is another one for boats with narrow splashwells that is much neater..<br />it fits into the whole where the current cables come out.<br />the new cable will fit into this and lock in place.<br /><br />both versions also have a bracket that goes between the cable and the steering arm on the motor, that allows the motor to tilt without bending the end of the steering cable...<br /><br />rgds<br /><br />Franki
outonbizniz
Frankie,<br /><br />If you have the teleflex part number for the piece that actually attaches to the motor...bolts to the handle somehow that would be great.<br /><br />The piece I have is identical to the one in the picture for pulley steering. I do have access to the circular rubber mounting part that goes into the splashwell (mine is narrow enough to use it).<br /><br />Could you take a few pics of the setup you have to help me picture it.
outonbizniz
^^<br /><br />Still with us Frankie?
crab bait
i can't believe you live in WISCASSET maine and havin' a problem findin' parts..<br /><br /> when HAMILTON'S ,,the best cottonpickin' marine store on the east coast ,, is in your backyard..!!<br /><br />if they don't have it,, it ain't made..
outonbizniz
Look at all the baits!!<br /><br />Snapper...no through tube on this old a motor...thanks for tryin though.<br /><br />Crab...I frequent Hamilton's...I talked to them first. I think they have some stuff that I could make work. I do know that evinrude made a bracket for these motors...One old Evinrude shop owner said "yeah, we had those, but I haven't seen one in a long time."<br /><br />Thanks all!
snapperbait
No dude, you missed it.. That is a tube.. Look a little closer... It bolts to the transom right in front of the motor... ;) i
outonbizniz
Thank you everyone!<br /><br />Mr bait...you are correct! That is an option! I didn't look as close as I should have.
