How to identify quicksilver repower engine size?
ShoalSurvivor
1999 Stingray 190LX, which came with a 190HP CARB A1 (as listed on MSRP sticker).
My engine was replaced in 2004, with a quicksilver repower engine. All numbers that I have are listed below.
He said it now has a 4bbl carb and is larger.
How can I determine if it's still a 190HP 2bbl, or if the new engine is larger, or is 4bbl, Gen+ or EFI?
thanks!
original engine SN: L332123 replaced with: 2004 Mercruiser 4.3L 225hp 4bbl Quicksilver repower SN: 90004747 (#807736R11 / 03252004)
Alpha 1 Gen II - Transom: 0L517680 Drive: 0L192679 1.62 R (1.81R scratched on top) original drive may have been SN: L40356
QBhoy
AC Chris will confirm shortly but I think if it’s now a vortec engine you will have a little more power than 190 you used to have. Maybe like 205 or something.
Probably not relevant but but I was recently schooled that the new 4.3 reman carb engines are 225hp for some reason...but not in 2004.
QBhoy
Oh jeez. Who knows. Your 99 original was likely a vortec too.
These reman confuse the life out of me !
thumpar
I don't get what you are asking. You list what engine you now have in the post.
ShoalSurvivor
the HP listed was based on a previous process of elimination from some web site. I wanted to know definitively what I have, and was hoping that someone would know.
Fun Times
(# 807736R11)
Is your model number and actually in-turn it's the engine part number from Merc....Using that number brings up some pretty good details regarding this engine just by searching the model number online such as this for example, http://cmmarinedistributing.com/index.php?_a=viewProd&productId=1717
If I recall correctly a good Merc parts guy can find a parts listing using the reman serial number but it's not easy so with that here is your parts guide to help them out if ever needed...., https://www.mercruiserparts.com/4-3l-gen--4bbl-reman-1g400000-u
Though there's a bit more to read in the first link above, here's the gist of it for you/those interested,
GM 4.3L 4-BBL Carb Gen.+ 262 V/6 (Left-Hand / Standard Rotation)
Replaces 1987 and newer GM 4.3L marine engine applications
225 HP @ 4800 RPM ‑ Standard / Left‑Hand Rotation ‑ Remaunfactured 4.3L Partially Dressed Marine Engine Assembly. Features Include: New 600 cfm 4bbl Carburetor, Electric Fuel Pump, Nodular Iron Crankshaft, Roller Camshaft, Vorte Cast Iron Cylinder Heads, Stainless Steel Valves, 9.4:1 Hypereutectic Pistons, Full Roller Rocker Arms and Thunderbolt V Ignition. Includes: Flame Arrestor, Harmonic Balancer, Oil Pan, 10‑Pin Harness, Water Pump, Spark Plugs and Wires.
Runs on 86 Octane Fuel
This Remanufactured Crate Engine is a universal power upgrade for V6 MerCruiser Alpha Sterndrive Applications and adaptable to other brands of sterndrives regardless of make
Note: If replacing 2000 and newer V/6 4.3L engines with metric fasteners, the purchase of SAE-Standard fasteners will be required to complete this installation.
Fun Times
Your original engine S/N 0L332123 shows as MERCRUISER 1 PC Exhaust system:eek:no wounder it needed a new engine :D W/PS 4.3L ALPHA (GEN +) (2 BBL.) GM 262 V-6 model number 4211015L1. https://www.mercruiserparts.com/4-3l...262-v-6-1998-1
0L192679 = MERCRUISER ALPHA 1.62:1 DRIVE model number 5121300LS.
0L40356 is missing a number but adding a 9 at the end comes up as an MERCRUISER ALPHA 1.81:1 DRIVE model number 5121400LS.
0L517680 = MERCRUISER ALPHA TRANSOM W/ENGINE Model Number 6111001LS.
https://www.mercruiserparts.com/alpha-one-gen-ii-1998-and-up-0l10004
QBhoy
Guys as far as I know the info given above for a reman 4.3 at 225hp....is only a recent thing. When yours was purchase away back then...it likely wouldn’t be at 225hp.
Fun Times
The differences with the remans are they tend to rate the H.P at the crank vs the prop-shaft like new engines do so bare that in mind too....Being these remans came with a 4 barrel carburetor for a long time now ought to of kept the H.P rating around the 225 crank shaft mark. And again the model/engine part number from years past helps tell a history of what it is/was.
The first link below also helps show a year range in question that looks bumped up a bit from the rest but that could be tide in with the MPI too.
96-09Roller cam with balance shaft. Has roller rockers. Block has metric mounts. 6 bolt timing cover. head casting should be 113. 8 bolt intake.200 & 230 H.P4.3L
262 CID
V-6090MGM262LJ
https://www.perfprotech.com/remanuf...ruiser-marine-longblock-engines/category/2585
https://goneoutdoors.com/specifications-mercruiser-43-7408867.html
QBhoy
Oh jeez I’m even more confused than I was, haha. Is that now suggesting that there is a 230 hp 4.3 ?
i know the mpi is 220hp and until recently thought that was the most powerful until l learned of the reman 4.3 carb at 225hp.
I also thought the Volvo Penta version of the same 4 barrel carb quotes HP at crank instead of prop and they claim 205/210 I think. Oh god knows.
QBhoy
What I was maybe trying to say was that a 4.3 carb reman in the early 2000’s maybe wouldn’t be 225hp. It would question the worth of the mpi 4.3 and it’s 220hp at the time. I think this 4.3 reman with 225 available now is only since the mpi version was ditched for the new in house merc 4.5
Fun Times
Believe the 230 meant to say either 220 or 225 for the V6 line.....Volvo went as high as 225 until 2015 then up to 240.
Volvo’s two feature multipoint fuel injection and are rated at 200 hp (V6-200) and 225 hp (V6-225)....,https://www.boatingmag.com/boats/43-...ndrive-options
4.3L Alpha 4V Product Data Sheet
225 Crankshaft Horsepower:
WOW! A V-6 that makes more power than a 5.0L V-8. Replaces 4.3L- and 5.0L-powered runabouts while delivering V-6 fuel economy: Nodular Iron
Crankshaft, Billet Steel Roller Camshaft, Vortec Cast Iron Cylinder Heads,
Stainless Steel Valves, 9.4:1 Hypereutectic Pistons, 1.5:1 Full Roller Rocker Arms,
Thunderbolt V Ignition with Knock Control, 10
Pin Harness. Runs on 87 Octane Fuel.
https://www.youtube.com/watch?v=3sKrrMCifVo
https://www.youtube.com/watch?v=lm7nNhSUbOw
A lot of any confusion ought to be tided up in the crank vs prop shaft rating specifications which is worth roughly around the 20ish H.P mark...Again new engines are prop rated and remans are crank rated.
https://www.perfprotech.com/blog/tec...specifications
reman is listed as flywheel HP, not prop HP (because it was not paired with a drive). so his 225 is accurate, assume about 190-205 ish at prop (drive dependent)
