RMasters
- Joined
- Jul 2, 2010
- 67
Here is another "strange" think happening.
I have 2 fuel tanks in the front, 1 in the back. The back one is different, works flawless.
The 2 front ones are new (Seasense), "worked" for a while, but now, once I advance the throttle beyond idle, my motor stalls and the primer bulb is squeezed, pretty much telling me that the fuel can not be pumped out of the tanks fast enough, which should be a vent issues.
The fuel line is in correct diameter and was checked by my mechanic, it works. Fuel pump pumps full pressure.
So I was trying to drill out the vent hole in the fuel caps. The vent holes are so tiny, you can hardly see them. But I can't get to them as the screw (on the outside) and the seal (on the inside) cover the hole.
Any ideas how I could accomplish this? The tanks are stored underneath, so no worries about getting water in it (if the vent hole was exposed).
Or do you think opening the fuel cap slightly till you hear the pressure going out would accomplish the same (as air can go it now). Or would I spill fuel all over the place?
This is another one of those things (I currently have another weird issue), it worked for quite a while, and suddenly it does not anymore. It is a simple setup, what could be possibly wrong?
