gmarshall43
- Joined
- May 5, 2002
- 214
I inherited a 6hp Johnson, model CD-25R. The pole rope mechanism inside had been taken off and it was laying inside the motor with the rope still attached and I'm not sure how it goes back on. It has a spring at the bottom and I'm not sure how to insert the unit into it's proper position. I know when I pull on the rope the gear at the top of the rope mechanism is pushed up to the flywheel to turn it by the spring at the bottom. I think once I get the spring insert correctly it will work. Any ideas?<br /><br />Thanks
