How to kill during test
G DANE
I sometimes jumpstart motors on a stand with muffs, only with battery cables bolted on the motors + and ground to save rectifier. Question now is, how do I easily rig some kind of kill-wire up, in case of runaway or simply just to stop motor ? Instead of letting them run out of gas, its much safer to be able to shut off. Could I make a temporary kill switch, connected to one lead in the big red plug and ground ? In that case at which pin # ?
marinetech43
Re: How to kill during test
G, each engine has it's own color kill wire. If you want to make a generic stop mechanism for carbed engines, try hooking a switch to choke (flood) the engine to stop. Otherwise, you will have to plug into the engines main harness with the proper plug connected, to kill the engine.
G DANE
Thanks for the reply, Marinetech<br /><br />I was just wondering if I could make a red plug with only connection to the kill wire pin for the ignition switch, to hook up to the plug to the ones i test. Isnt that always same pin ?? What do you pro´s do in shop.<br /><br />By the way, its still a bit hard to get OMC parts here in DK after Bombardier took over. Many dealers, but most have second to no stock - a pain.
