How To Know What Prop
kingjoe
How can I find out what props would work for my 1990 60 HP Mariner??
Replies appreciated....
Silvertip
Re: How To Know What Prop
You look at the application charts right here on IBoats. You input the year, make, and HP and you will be given a list of props. Three blade, four blade, stainless, aluminum, and about a gazillion pitch selections. Look at the prop you have now for the pitch. Buy the same pitch and go boating.
Here is the link to the IBoats prop section:
http://boatpropellers.iboats.com/Ma...ers/?chart=52&engine_id=274&*******=498902471
steelespike
If you read the stickys at the top of the page and the helps on the prop store page.
it will help.If you do a light load test run and get us all the info on your boat, motor etc and your wot max rpm and speed we can tell if youre setup is working and may be able to make a suggestion.
