How to lower charging voltage
TRAILN
Hi,
I've got a '88 Johnson 60HP 3 cyl. and it charges at 16.5-17.0 volts at cruising speed. I hear its normal to charge this high on a non-regulated system. Is there any way to add a regulator to it? Is there any way to drop the voltage down a little?
I just installed a automatic charging relay and it has a over voltage lockout at 16 volts. Kind of defeats the purpose of having a ACR if it doesn't charge the second battery.
Thanks
boobie
Re: How to lower charging voltage
BRP has one, part # 173640.
