how to pressure test lower unit
licketdsplit756
title explains itself ? what pressure to use and how i can do it with my air compressor?
Xcusme
Re: how to pressure test lower unit
Drain low unit. Adapt an air fitting to drain opening. Pressurize to 8-10 lbs. Place lower unit in test tank and look for bubbles. Leaks should be obvious. A bicycle pump works just fine
