cheburashka
- Joined
- May 28, 2005
- 715
Last summer I put an external oil reservoir on my pre-alpha outdrive. It uses a fitting that goes into the vent hole on the top of the drive, and a hose that goes through the transom into the engine compartment. I drained the oil when I pulled the outdrive to grease the u-joints. I've re-connected the hose to the barbed fitting, but now I'm not sure how to re-fill the outdrive. Do I refill the reservoir and wait for it to drain into the outdrive, or do I still have to fill it from the drain hole like I did before it had the external reservoir?
Thanks
Thanks
