How to Put Small Gauge in Large Hole?
Ernest T
I want to add a water pressure gauge to my boat. The gauge is a Faria and requires a 2 1/16" hole. In my boat's console, there is already an existing unused 2 3/8" hole that has a plastic plug in it that I would like to use. Is there a bushing type thing for this situation? Or another way to do this. The material where the existing hole is appears to be plastic not fiberglass.
Thanks for any help! :cool:
TahoeQ4Pilot
Re: How to Put Small Gauge in Large Hole?
What about just leaving the plug in place and drilling a 2-1/16 hole in it and mount your gage in the plug??
Ernest T
Not a bad idea, as long as the plug doesn't try to pull through when I tighten the gauge. I'll have to get behind the console and take a closer look. I contacted Faria, and they didn't have any ideas, so I may try using the plug as a bushing or making my own.
Thanks for the idea!
sschefer
You can buy bezzels that take up the extra space. Livorsi and Gafrig sell them and there are a few others also.
Fed up
remove the plastic plug, take a nice piece of AL and cut out a piece to fit tightly inside the plug, then epoxy in. now drill your hole, should be better than ever.
