Re: How to raise alternator Voltage?
ndemge said:
I have a 48v battery bank (54V Float) That I would like to rig up an alternator to charge. Looking to get 40amps DC at 54v
Can you run regular alternators in series? or modify to get a higher voltage?
The easy answer to your questions is YES!
You can change the VDC of your alternator from 12-16 VDC
Normally about 13.8 VDC
And yes you can put the output DC in series to get 54 VDC.
But why?
They already make 48 VDC alternators. Heavy equipment.
They peak at 54 VDC to top off if you will.
And the cost will be about the same.
But that alternator will take about a 13-14 HP gas motor to run it.
