I have a 2005 alpa one gen ll. one trim cylinder has a very small oil leak at the rod oring. so ive removed the round cap with a spaner tool. Im trying to pull the piston & rod assemble out but it feels spring loaded or maybe it need air behind the piston? How do i get air behind the piston? once i replace the orings and reassemble the cylinder do i need to bleed the air out? and if so how? is there a rebuild instructions on the web?
