1980 Johnson 25 hp LONG SHAFT. I have the entire lower unit removed, but now I have to remove the extension housing (not the gear housing). I removed the four bolts, but the extension housing is still stuck on the long stud bolt. Any suggestions to break it loose without damaging anything? I whacked it good with soft mallet, soaked the seam in WD-40,... The corrosion has it locked tight unless I'm missing something that's not in the book. Help!!!
