I have removed all the bolts and the lower will move down about 1" and seems to get stuck? I have tried in neutral forward and reverse. Perhaps something to do with the shift linkage? Is there some way I need to disconect it? A little pointer here would be appriciated.
The reason I am removing it is because I want to replace the water pump. I havent started it in 2 years and when I did I wasnt getting much flow out of the telltale. I always had good flow before. I checked the telltale tube and it is clear of blockage.
Thanks.
Thanks.
