DunbarLtd
- Joined
- Nov 8, 2016
- 357
1988 Force 85hp 856X8A
Well its bad news...... last time out about halfway across the lake I heard a nasty sound coming from the lower unit enough to stall the motor. Used the trolling motor to get back to the docks. I had just changed the oil 2 weeks ago too with Quicksilver 90wt.
Anyways to get right to the point, I have removed the spool and the reverse gear off the shaft. I looked in with a flashlight and the forward gear has just completely shredded its teeth. There was also damage to the pinion gear (drive shaft gear) as well. The reverse gear has one tiny chip on only one tooth from what i saw. The needle bearing looks fine.
I ran the motor in reverse gear no problem, but when i tried to put it in forward a couple times the nastiest grinding sound was heard and it would stall the motor. So after only two attempts i stopped and just used the tolling motor to get back home.
Would love to know why that happened???
I found a replacement gear assembly with bearing for actually a fair price. Ive read that its recommended to just buy a used lower unit rather than try to repair these things because of cost. Well since I found a good deal on the gears I will do this repair.
I removed the pivot pin. Now the next step I believe is to pull the propeller shaft but it seems like its in there pretty good. Shouldnt it just slide right out because in my service manual it just says pull the shaft out. It says do this while the reverse gear is still on but i got a hold of it and removed the reverse gear first. Thats when i noticed the forward gear teeth ground off.
Anyways any helpful tips would be appreciated. Thanks.
