How to remove the remote?
Skyhog
I need to replace the neutral safety switch I thin . But I can't figure out how to get at the bolts that hold the remote in place. I took off the panel and see the bolts coming through but there's no access from the front....any ideas?
Picture here:
https://photos.app.goo.gl/G9ryfgkzBe6c5kEY9
GA_Boater
Take off the throttle lever. That's where they hide.
GA_Boater
The bottom of the throttle has a slot. Push the throttle forward or pull it back in reverse until you see an allen key and remove it. I think it's forward. Anyway, after the allen is removed, the handle should pull off.
Skyhog
Thanks. I'll give that a shot when I get back to the house. I dont see an actual neutral safety switch here...is it possible that the whole thing serves as the neutral switch?
GA_Boater
You'll see the switch after the back side is out.
Skyhog
I assume it's this guy right here?
If so, is it as easy as just dropping the new one in or do I have to do something fancy to make it know it's in neutral?
Also, I'm not finding that part number anywhere. 1265RA4 it appears...any advice?
GA_Boater
Looks like it.
What remote control you have? That's the easiest way to find parts.
GA_Boater
You can test it, too. It may need the position adjusted.
Skyhog
It exploded in my hands when I took it off. It was cracked. No adjustment in the world is fixing this one.
How do I find the remote model? It's off a 1996 Dynasty Bos Rider Elanti 180 if that helps
