How to repair paint?
Slow Ride
I purchased a used boat and did not realize it had been repainted. In an effort to bring some luster back to it I used rubbing compound which only served to dull the little bit of luster it had. Are there any products out there I can use without having to have it repainted?
chriscraft254
Re: How to repair paint?
You can try to wet sand it with 1000 grit wet paper. Then 1200 and 1500. Might do the trick.
Ayuh,... That's only step 1 of the process,...
Ya need to keep buffing with finer compounds....
If ya don't run outa paint...
