How to replace gas vents ?
Toula
Hi, snapped off the gas vents on the side of the boat, now how to replace them as there appears to be no access from the outside. Have the replacement vent but need guidance how to replace on a 2005 sylvan. Appreciate the insight as always.
Watermann
I would imagine without seeing a pic of your boat that the side panel inside must be removed to gain access to the clamp on the inside to remove the vent line and install the new vent fitting.
