Re: How to replace gimbal bearing in 165hp Inline 6 cylinder
i did my bearing and bellows on a 78. i rate it a major job because of the special tools required (bearing puller, bearing installer, alignment tool) and the extra work to get to the bearing (pull the shift cable out of the transom/reinstall shift cable, remove the trim senders (won't work afterwards because wires are rotted),...). it can be intimidating at times. i had access to a machine shop to help me out and sometimes i just had to walk away from it. the dilema is that the work at a shop and parts can cost more than the boat is worth. i took my time and had a manual and with the forum's help and websites got it done over winter. the forum members will help you out maybe with tips and helpful information. one tip now; drain the outdrive and after you remove it, be darn sure you place it somewhere it will not get knocked over or just lay it down, and the outdrive is heavy; it comes off with the help of gravity, but replacing it, you have to lift it or use a lift. i would suggest looking over the websites and reading posts here from those who have done it and then decide what to do.
