How to replace Impeller on 1995 DP-C1 also gasket and part numbers
Navigator_Victory
Going to replace impeller as I have no idea the last time it was changed however I am having a tough time figuring out the part number and also finding instructions for doing this task.....yes I looked at the links and downloaded the adobe files but, still can not find a step by step procedure to replace impeller.
I also need the part numbers for the impeller and part numbers for the gaskets for the drain and fill plugs.....happy to buy them from iboats if it is easier to just post a link to the parts ????
Thank You in advance
Don S
Re: How to replace Impeller on 1995 DP-C1 also gasket and part numbers
For one thing, the DP-c1 is an outdrive, not an engine. There are no raw water pumps in Volvo drives.
Here is a link to the OEM parts list for your engine http://www.volvopentastore.com/Mari...on_id.731342063--store_id.366--view_id.765142
Here is one for the drive. http://www.volvopentastore.com/Mari...on_id.731342063--store_id.366--view_id.765056
If you want to go with aftermarket parts, use the part numbers you get above and use them to cross reference into the aftermarket parts.
There are links to parts just above this thread.
Install instructions are in the engine manual.
Navigator_Victory
So to clarify the first link is everything involved in cooling the engine? or is that just one part? also where does the water come into the engine? I am assuming down by the prop but, I am giving up on assuming any more. in fact I do not even see the pump listed on the diagram it is sort of pictured in the lower left but, no part # ?
Is there a diagram anywhere show how the water comes into the engine where all it flows and where it exits?
Thank You for your patience
Don S
Go to the first link I gave you, then click on Cooling System - 7748040 then go back to the main link again and click on Intake And Exhaust System - 7748040.
Flow diagrams are in the service manuals up in the stickies.
