I want to be able to siphon gas from the 56 gallon boat tank for emergency use or when I need fuel for a car / yard equipment in a pinch. I currently have a bulb type hand pump that's not doing the trick. Its plenty long enough and uses 1/2" diameter tubing but it doesn't work on my boat. Does anyone have a CHEAP (under $20) alternative to this type of siphon or any advice?
Thanks!
Syphoning is best down under the cover of darkness. I find a night with a lot of wind also helps cover any noise. Avoid places with dogs!
3 suggestions to help you...
1) make sure you have the bulb facing the right way (obvious I know, but you'd be amazed how many people miss that one :facepalm
2) Bulbs prime best when they are pointed up. The valves don't work facing down, so you can't prime the syphon. Once you have the fuel flowing you can turn the bulb to face down.
3) Make sure the end of the tube is LOWER than the level of the fuel in the tank. And the lower you get it, the faster the fuel will flow....
Chris......
