How to Sraighten Aluminum Top Frame
1stgenbird
I have an old cockpit cover/bimini top from a '73 Silverline 19ft that I just bought. One side of the 3/4" aluminum frame is bent so it won't fit in the side channel. What is the best way of straightening out the bend? I never had good luck in trying to straighten aluminum tubing as it always bends in half.
jigngrub
Re: How to Sraighten Aluminum Top Frame
You might try a tubing bender or conduit bender, but your best bet will probably be to replace it, it'll look better and last longer.
Bob_VT
Another trick is to fill the tubing with sand which helps prevent kinking ;) and MOST electricians have conduit bender's in their tool kit.
1stgenbird
Although I have never used a conduit bender, I believe the purpose of those is to take straight conduit and bend it. I want to do just the opposite.
As a last resort I would consider buying a new one but all I have seen for sale are full Bimini top frames, not just individual pieces.
Looking for some Yankee ingenuity.
1stgenbird
I may try the sand trick. I have heard of doing that but never what the end result is.
jigngrub
Conduit benders work the other way to, to straighten... bend it in the opposite direction.;)
1stgenbird
Yup. I see that now. I think using one of those and filling the tube with sand will do the trick. Thanks
