how to start it
anthony115merc
i have a 25 hp merc dont know how to start it was rebuilt and used 3 times since and has lots of compression makes it hard to pull start has two switches on the control run/off and off/? and the throttle/shift cables are unhooked do i apply some throttle where should the choke be set? should i put new plugs since it was last run 3 yrs ago?
tashasdaddy
Re: how to start it
here again better pic would help. follow the instruction is gave you on the evinrude, awakening a sleeping outboard. the carb controls are different for the merc. a pic of the front so we can see what controls it has.
anthony115merc
Re: how to start it
the controls are forward controls i removed the cables for transport everything should be set right as done when was rebuilt i just want to get it running give it a quick check and sell it
studlymandingo
Re: how to start it
Are you getting spark?
Buy a spark-gap tester at your local auto parts store (they're cheap), pull the plugs and hook the tester to each wire one-by-one giving it a crank each time. You should see a nice blue spark on the tester. If not, that gives you a starting point.
Yes, I would reccommend new plugs.​
anthony115merc
Re: how to start it
ill get one and give it a go should i apply some throttle when starting it
anthony115merc
Re: how to start it
had another go at starting it.im starting to get a sore arm now only somany times i can try then i have to have a break any suggestions?
jimlad
Re: how to start it
are you getting fuel to the spark plug is fuel fresh and right mix :)
anthony115merc
Re: how to start it
i am not sure about the fuel mix its fresh but i just poured about 100ml oil to 3.5L of fuel
jimlad
Re: how to start it
after you try and start it check the plug to see if it is wet with fuel.
also have you replaced the spark plugs if not i recommend you get new ones
anthony115merc
Re: how to start it
i havent got new plugs but i will look into getting some and checking for fuel
