2000 Johnson 25 - 2 cyl requires choking when cold. Problem is that the gas drips off the choke handle when pulled all the way out and runs off the handle when half way in. No problem starting or leaking after engine starts. Usually floods but starts after 15 minutes. Do I need to replace the choke assembly? This is a great motor otherwise. Thanks in advance for help.
