Re: How to tell if oil is mineral or synthetic?
"They" are Volvo Penta....The OEM who probably knows a thing or two about the products "they" design and build.
"They" don't build the engine.....and they sure didn't design it.......
This is really "Much ado about nothing".
Marine engines do not fail because someone switched from Syn oil to regular or vice versa.......
They also don't "last" longer.
They fail for "other reasons", like not keeping enough oil in the sump, NOT changing the oil (with ANY TYPE) for YEARS.......leaving water in the block(and it freezes), not changing the risers/gaskets/manifolds when they should, the list goes on..............
Oil
type is so far down the list that it is NOT significant(or not even on the list).
Use what ever makes you feel good and you'll be in a VERY large "
club".........the "I use XXX oil and I've never had a problem"
club!!
In fact.......we're all in that club!!
Pic says @ -35 degrees Celsius.
I doubt he has a freezer that cold.
Yeah, I'd like to see a pleasure boat that operates in -35C weather too!!
Cheers,
Rick
