Re: how to tell if your points or condensor is bad?
Even new points sometimes have a film of oxidation on them that prevents proper contact. You check them with an ohmmeter that is capable of reading less than one ohm. Do you have one and know how to use it? You can also use it to check the resistances of the coil windings and spark plug wires. And if it's an analog meter, you can do a crude condenser test too. However, there also are digital meters with a capacitor test function and they will show actual capacitance in mfd's. But a digital without capacitor test function won't tell much about condensers.
