Im a little confused as to the proper way to do this. I read the manual but its talking about neon lights and other things I don't have. I have a multimeter. Can I do it with that?
Its a 76 johnson 55hp I only have spark on one cylinder. First thought was coil. So to check coil I switched them. Now the coil that wasnt firing is firing. So now I am at the power pack. I understand it has to receive a signal to switch from coil to coil so I suppose it could be that it is not getting the signal to switch. Not sure how to proceed at this point. without the neon lights to test with.
