Re: How to test a rectifier/regulator ?
Hello CSABA,<br />I don't believe that the engine you have has a regulated out put, yours I believe has three wires comming out of it. I don't have a manual at home, so take this with a grain of salt.The wires will be colored yello-yellow with a grey stripe and red. The red wire is the output +, the case of the rectifier acts as the negitive side. The yellow, and yellow/grey are the stator output which is AC. The proper way to check it is with an ohmmeter set either on the diod scale, or a low ohms scale. You will be checking the front to back ratio on each of the diods,there are 4 diods in the case that make up the bridge network. So if you hook the 2 meter leads between any 2 leads from the rectifier, or case the meter should read very high in one direction, and zero when the leads are reversed. Keep doing this until all possable combinations are measured. If all of the above steps check out it's a good rectifier, but if any one of the combinations dosn't pass the high-low test you've got a bum rectifier.<br />I hope you can make sense out of all this.<br />Good Luck
