wvmedic
- Joined
- Jun 3, 2008
- 534
I have tested a known bad coil using 20K ohms to test it + probe to plug wire ? probe to the two wires on the coil, I get 2.02 on both leads.
I did the same test on two new coils with the same results; I then test the known good coil and get a zero reading on the same test.
You ask how I know the one coil is good, well while the motor is running I pull one plug wire at a time. With the good coil running the bottom cylinder the motor stalls when I pull that plug wire, old and both new coils on top cylinder no change when I pull the plug wire.
Ok so I switch coils known good coil to top cylinder, new coils to bottom cylinder. I then pull the top plug wire motor stalls; fires the motor back up then pull the bottom plug wire no changes.
1973 50 HP Evinrude.
Any ideas?
Thanks Jeff.
Any ideas?
Thanks Jeff.
