Re: how to test powerpack 77' 115
A rough running engine may be due to interaction of the Power Packs because of faulty isolation diode in Power Packs. The diode may be checked by using ohmmeter set to high ohms scale. Check it as follows:
1. Disconnect leads from power pack terminals 6 and 11
2. Connect ohmmeter leads between the 6 and 11 power pack terminals. Note the reading.
3. Reverse the ohmmeter leads and note reading. Infinite or very high reading in both directions indicates diode open. A low ohms reading in both directions (approx 100) indicates a shorted diode. A normal diode will read resistance in one direction and infinite reading in the other.
4. If the diode is defective you willl need to replace the power pack.
Joe Reeves is the master and can explain why the pack fails best.
(MCD Powerpack Failures - 1973 +)
(Magneto Capacitance Discharge Systems)
(J. Reeves)
The usual cause of having those type powerpacks fail repeatedly is having a very small of voltage applied to the Black/Yellow wire at the pack. Test as follows.
Disconnect the Black/Yellow wire at the powerpack.
Insert either an ampere meter or a volt meter set to its lowest DC voltage reading between that Black Yellow wire and ground.
With the ignition key in the OFF position, observe the meter reading. Now turn the ignition key to the ON position and again observe the meter reading.
Any reading, movement of the meter needle, would indicate that battery voltage is being applied to that Black/Yellow wire. If a reading is present, remove the other end of that Black/Yellow from the raised terminal of the ignition switch.
If the reading ceases to exist when the Black/Yellow wire is removed from the ignition switch, replace the switch. If the reading continues to exist, there would be a short of some kind in either the engine or instrument wiring harness.... to determine which, simply unplug the large RED electrical plug at the engine which would eliminate the instrument cable.
