How to test powerpack for 200hp ?
fish2day
I have a 1991 Johnson 200hp that will not run over 3000 rpms. It has fire to all plugs, good compression, but trembles like it is missfiring. Idles and starts good, but is weak and will only climb to 2500-3000rpms. Is there a way to test the powerpack?? The Stator?? and the trigger?? Any advice appreciated. :confused:
bernd64
Re: How to test powerpack for 200hp ?
yes you can test all of this thinks but you need to have a repair manual for your motor the explan it how to test the components.i use selog the a petty good and i have an outboard shop to
boobie
When you say "fire to all plugs", how are you testing it??
First off don't mess around with those off brand one size fits all manuals. Get an OMC factory service manual for your engine, you can often find them on ebay.
It kinda' sounds like your engine might be going into SAFE mode. If it senses a high temperature condition the power pack limits the engine to about 2500 rpms, and when hits the SAFE mode rev limiter it runs like crap.
dwco5051
Go to the CDI website and download the installation and troubleshooting guide for your power pack. I think the part number for your power pack is 113-3865. There are some sensor inputs to this power pack that will limit engine speed to around 2500.
www.cdielectronics.com/InstallSheet/113-3865.pdf
