Re: how to test powerpack
The way to test a powerpack, is to be sure it has:<br /><br />>good grounds<br />>proper trigger voltage (peak reading meter required)<br />>ample charge voltage (peak reading meter required)<br />>no grounds in the kill circuit<br />>good ignition coils attached<br />>good connections at all plugs<br /><br />If all above are OK, and you have no spark, the pack is bad......
