Alpheus
- Joined
- Aug 3, 2009
- 1,759
I found this post by Silvertip on another section on this forum. I though it could be used here. I just changed the wording a little and added a couple of lines...
If one scrolls through the first few pages of this forum you will find that there many questions regarding boat outdrive repair . Many of those questions usually have the same or similar answer. Location of drain plugs,what oil,wont idle,no spark routinely appear. Before you post your question, look through the forum or better yet, use the SEARCH feature to see if you can find an answer to your question. It is very tedious to answer the same question over and over again. Here is how to use the SEARCH feature.
If this does not answer your question click the Advanced Search then in the Search By Keyword box make sure Search Titles Only is selected. If you need to search for a word with three or less letters, use the + in front and after the word (Example +oil+)
