How to vent a boat cover?
subkron
Purchased a Sharkskin cover from iboats - works real great but the condensation is a killer.<br />What is the best way to vent the cover? It fits real tight so I can't leave an opening. How about the kind that you cut a hole and mount a plastic housing around? How many are needed?<br /><br />Anyone have links to vents?<br /><br />thanks...
NCOffSeason
Re: How to vent a boat cover?
I have the same cover and the same problem. I use this - Overtons part # 26666.<br /><br />
subkron
Thanks NCOffSeason.<br /><br />Any one else?<br />^^^
Lou C
I also have a heavy winter cover that does not breath that well, I put 3 of the large size moisture buckets shown to absorb the moisture.<br />Overton's sells vents that you can install in the cover, but you may not want to cut into a brand new cover. Try the moisture buckets first, if you still find a lot of moisture esp on the underside of the cover, you may want to put in the vents to allow air circulation.
crazy charlie
If you have electric near by just put a fan in side and put it on a timer.I always leave a fan running in my cabin and I find that the moisture is eliminated.Charlie
subkron
Thought of that, but when I lift the cover I smell gas fumes since the cover doesn't breathe.<br />Kaboom.
crazy charlie
Unless you have a dangerous gas leak there is no kaboom from turning on a fan.What do you think a blower motor is?????Charlie
mattttt25
do you run your blower with your winter cover on? not a valid comparison.<br /><br />i wouldn't run the fan. stick with trying the moisture buckets suggested above.<br /><br />good luck-
DC698
I recently purchased a heavy duty boat cover also and noticed a lot of condensation underneath when I took the cover off. Decided to go with the Ameri-Vent snap in vents. They come in pairs and are 3" in diameter. Here is the link to where I bought them. Checked with IBoats, but didnt find any in the mega-mall. They were cheaper here than at overtons.<br /><br /> http://www.websweeper.com/php/boat_covers/bc-019.php <br /><br />Also, on a side note, when I store the boat when not in use, I slide the engine cover back maybe 8 - 10" to expose the engine compartment a little to allow air circulation throughout and help keep condensation off any metal parts. Hope this helps.
bob58
mattttt25 <br /><br />do you run your blower with your winter cover on? not a valid comparison.<br /><br />i wouldn't run the fan. stick with trying the moisture buckets suggested above.<br /><br />good luck-
@mattttt25 <br />Yes I do. So do alot of inboard cabin cruisers and I/O's.<br />They have full canvas enclosures and the blowers<br />are made for removing any volatile fumes so that they still have a vessel in one piece after turning over the engines!<br />If fuel vapors are building up it is time to check vents, hoses clamps etc.<br /><br />@subkron<br />DrizAir canisters or a dehumidifier will work well for drastically reducing your condensation problems!
crazy charlie
I still recommend the use of a fan as I have used one for 20+ years without a problem or humidity.I also use the drying pellets but they are not for everyone.I can get into my boat through a zipper to empty and drainoff the water collected in the canister.The drainoff is a step that most forget to do.If you have the condensation that you claim,the drying pellets will be used up within a week.You will have to drain and refill often.Charlie
airman
I bought a household dehumidifier and ran the drain tube out the drain plug hole. $100 in the classifieds for a good used one. Dusty dry in a day and I leave it unplugged most of the time. I just ran an extension cord out thru the cover so I can plug it in for a few hours occasionally.
