How to verify fuel lines etc are updated for ethanol?
divimon2000
I bought a 99 Johnson 90 and was wondering if there is a way to check the lines to see if they have been updated. May give me a clue if the carbs have been too? Thanks.
tashasdaddy
Re: How to verify fuel lines etc are updated for ethanol?
should say alcohol resistant on them. B1 rated.
Dhadley
The new rating for the line is an A-1/15 rating. The carbs on a 99 should have the viton components.
divimon2000
Great! Thanks for all the great help on this board.
D_Dose
How oftern should you replace the engine fuel lines?
I bought a '95 XR6 150 with less than 300 hrs. Very well mainteain and the maintenance records do not indicate that engine internal fuel lines were ever replaced. No signs of hose debris in the fuel filter (yet), but I'm having a slight hesitation at 3/4 throtel. Still run great once you get past that slight hesitation at 4000 rpm. If you accelerate slowly, not hesitation at all.
Is there a good source for a kit?
