I would like to know the proper way to winterize a 1995 Mercury 115 HP 2-stroke motor that only runs the top 2 of the 4 cylinders at idle speed. I want to remove all the gasoline from carburetors before I put the motor to storage. But the usual way of winterizing doesn't remove all the gasoline from the carburetor (run it for a while and then spray fogging oil until the motor stops). Moreover, this motor only runs the top 2 of the 4 cylinders at idle speed anyway. Therefore, the bottom 2 of the 4 cylinders are not running anyway. I am wondering how to properly winterize this motor. Should I try something like this:
1. Add stablizer in fuel (this I have been doing anyway). I don't need to pre-mix oil because the motor is oil-injected.
2. Remove the silencer from the outboard in order to reach the air intake of the carburetors.
3. Run the motor at higher speed than I normally do during winterizing to force the motor to run on all 4 cylinders. Of course I will not put the motor in gear. Let it run for 10 minutes to make sure treated fuel is inside the fuel system. How can I tell if the motor is running on all cylinders? Do I run the motor in a water tank instead of using an ear muff to properly cool the motor that is running at moderate speed?
4. Disconnect the fuel supply from the motor, and start spraying fogging oil into the air intake of each carburetor. Because the motor is 2-stroke, it needs oil to lubricate the engine. Without fuel that has been mixed with oil, the engine will not be lubricated. Therefore, I need to spray fogging oil to keep the motor lubricated. Keep spraying fogging oil until the motor runs out of fuel and stops.
5. Drain the fuel bowls. They should be empty by now (hopefully).
6. Put the silencer back to cover the air intake of the carburetors.
7. Remove the spray plugs and spray fogging oil into the holes. Cover the holes with a rag to avoid oil spill. Try starting the motor in order to ciculate the fogging oil inside each cylinder. Put the old spark plugs back.
8. Move on to the lower unit...etc.
Does this plan sound right? Is there anything that I should change?
I talked to another boat owner (who happens to be a car mechanic). He said he would not run the motor dry. He would drain the fuel bowls from his motor, and then he would use compressed air to blow all the fuel from the carburetors and the fuel lines. But he said this is tricky because someone can mistakenly blow the float out of alignment or something like that.
Please let me know what you think. Thanks.
Jay Chan
Jay Chan
