How to winterized?
Sherry47129
I have a 1995 Evinrude 90hp and am needing help with witerizing my motor, could someone please explain to me in detail how to do so?
Thanks So Much
204Angler
Re: How to winterized?
Leave motor tilted all the way down (verticle), remove spark plugs and use "fogging oil" in all cylinders, replace spark plugs, top off gas tank and a couple gallons of startron or seafoam, put tape or cover up the pee hole so no dobbers or other critters can get in and make it their winter home...change lower unit oil and BE SURE it is completely full of foot oil...you dont want any moisture in the LU if you are in an area that freezes. Make sure at first use, you drain some so it is down to usable level. Rubber band a freezer size ziplock bag over prop to keep weather out of hub and spline (AND prop :) ). Spray a little bit of anti-corrosive spray on motor mount and tilt/trim hydraulics to protect them from weather. I think that might be about it. OH and disconnect your battery and store it in a climate controlled area if possible...that'll help it keep a charge
