how to wiring the gauges on a johonson seahorse 70hp
carlos bairo
hi guys .i am looking to wiring my gauges on a johnson seahorse 70 hp 1981 model.
i have looking in to the forum to copy some advice ,but i feel confuse and i need a helping hand and a diagram to do the job .
1 i have a switch from the commander center with 3 cables-purple-red-black.
2 the connection from tilt rely flat switch 3 wires green-blue-red-.and on the some connection 2 small wires with eye
black/brown -withe/brown,no idea how to wiring them on my gauges
thanks for any help
i like to connect a fuel gauge/trim tilt/tachometer/ and speed=,
Chris1956
Re: how to wiring the gauges on a johonson seahorse 70hp
Fuel gauge needs purple (+12VDC), black(ground) and a wire from the fuel tank sender (usually pink). Tank must be grounded as well.
Tach needs purple and black, plus grey wire from stator to provise RPM signal.
Tilt gauges are pretty much useless. Install a water pressure gauge instead. Both water pressure and speedo need purple and black, plus plastic tube from nipple on water jacket or speedo pitot.
emdsapmgr
You can feed the dash tach from the 3 wires at the control box. All other dash gauges should be wired direct to the battery with a 20 or 25 amp fuse. The engine's 20 amp fuse could blow if too may electrical devices (gauges/bilge pump/lights/horn) are wired through the key switch. If that 20 amp engine fuse blows out on the lake, the engine won't start.
carlos bairo
hi thanks guys for you advice, i an rally appreciate your help.
carlos
