How???
HollaGeo
I am looking to buy an aluminum "row-boat" kind of thing. Maybe one that can hold a 15 H.P. engine. I see many on Craigslist that would work. However, they don't have steering consoles. I have done research on-line and have found consoles that I think you somehow bolt onto the floor. Usually, they are for inflatables. How would I bolt something to the floor and not make a hole thru the hull???
crb478
Re: How???
each boat would be different, but you can probably build a frame that is bolted through some of the ribs or cross members and the bolt the console to the frame. Going through the hull is not a good option. Each boat and each console would be a custom application.
tashasdaddy
Re: How???
you can use remote control for the motor on the starboard side, and ezyglide stick steering on the port. this was my 3rd boat with this set up. and i loved it. iboats, has the mount bracket in the store for $20-30.
puddle jumper
Re: How???
Look at the 2nd pic and you will see a leaver that as you move it back and forth it moves the motor left and right.
tashasdaddy
Re: How???
you mount your engine controls on the starboard side, and the steering on the right. you move the lever forward and back to steer the boat. it has a teleflex, cable set up. the steering helm is just the difference, stick instead of a wheel. the blue circle is the steering the green is the motor controls.
HollaGeo
Re: How???
That's kinda cool. I'm gonna look into that. Thanks everybody...
