Re: HP advice
stay away from a large HP four stroke....... it will most likley weigh too much. if you limit yourself to a 70 hp you can get an nice OMC-BRP 3 cylinder motor that gives you almost your max HP, but with a lot of weight savings over any 85 hp unit you could buy!!! Yamaha makes the lightest 90 hp available...it is a 3 cylinder...but technically it is OVER 85 hp!!! most any 85 hp motor you find will weigh at least 315 lbs good luck....bob
