Re: HP Laser Jet 1100
Ahh yes, the venerable LJ1100. Good little printers, but they did come with a proprietary printer cable. It's about the only example I can think of where the cable comes with the printer.
You could get a USB to Parallel port adaptor like
this. You could also install a little wired or wireless print server up on your home network. Or if you have another computer on your network plug it into that and share it.
By the way...
If it hasn't already, it's going to start feeding 2,3,4...25 sheets at a time. If you like it, don't throw it away. The parts are about 35 bux and not hard to replace. The roller and pad just get worn and it can't grab a single sheet with the precision it used to.
