cheburashka
- Joined
- May 28, 2005
- 715
'97 Maxum with Alpha 1 outdrive and 4.3 engine.
I bought a Turning Point Express prop based on the markings on the Michigan Wheel prop that I destroyed. The Michigan Wheel prop was marked 14x23, and I went down in size to a 14x21 for better hole shot. The prop I got is 4" in diameter at the interface with the outdrive. The outer edge of the hub rides in the middle of the exhaust flow and just looks wrong.
Is the difference between 14x19 and 14.25x19 a difference in hub diameter? Are all props marked 14.25 4 3/8 at the interface with the outdrive? I want to make sure I get the right part when I exchange this one, which clearly doesn't work well with my boat.
Thanks
Thanks
