I am not sure if this really belongs in this forum, but I need advice. I have a 1990 Sea Ray 180 BR OB. Boat has some damage to rub rail on port side, right about where the side windsheild is. The rail is pulled away from the hull, and I discovered that for about 2/12 to three feet of length of the rail, the screws that hold the aluminum extrusion to the hull have been pulled out or sheared off. I understand that the best way to fix this is to pull the rubber insert back in the channel (slide it without removing it) to expose the screws, then replace the screws (I will probably use small bolts instead because I can get to the joint on the inside to secure the bolts with nuts - and probably put them through a thin strip as a backing on the inside of the hull).
My question is whether there is anything that should go between the cap and the hull such as a caulk or an adhesive. I can't tell if there was anything there before.
Sorry I don't have pics.
Thanks in advance for any help. This site is a wealth of info.
