Hull dimensions required
Bournville
Hi,
I am taking delivery of a 2006 Trophy 1952WA with i/o Mercruiser. I would like to buy the trailer before I received the boat.
Does anyone know where I can get dimension drawings for the Trophy 1952 WA hull shape? I want to check roller/bunk and post positioning on the trailer.
Thanks for any assistance.
Bournville
apache61
Re: Hull dimensions required
Go here and lots of correct info
http://www.trophyfishing.com/archive.asp?modelid=54066
this is also from thier web site
2006 Trophy 1952 Walkaround
Email A Friend | Print Model Info
Specifications
Type Without Trailer With Trailer
Length Overall (LOA) 19'1" (5.82 m)
Beam 8'0" (2.44 m) 8'6" (2.59 m)
Approx. Weight (w/Base Engine) 3,240 lbs (1,470 kg) 4,090 lbs (1,855 kg)
Length Rigged 20'1" (6.12 m) 26'11" (8.20 m)
Height Rigged 9'2" (2.79 m)
Draft Hull 1'5" (.43 m)
Draft Max 2'11" (.89 m)
Bridge Clearance Max 6'1" (1.85 m)
Fuel Capacity 55 gal (208.2 L)
Baitwell Capacity 13 gal (49.2 L)
Dead Rise 17°
