Rellik546
- Joined
- Feb 5, 2011
- 270
I just bought a 1988 wellcraft 170 classic. apart from needing a much needed scrub down the hull is in pretty solid condition minus 3 gouges.
what would be the proper way to repair these?
bondo? or marine tex? then resin, or should i glass over it?
The boat is chaulky and i want to restore its shine, ive read forums on how to wet sand then rubbing compound then polish and wax. however how do i paint over the repair? do i primmer then use paint then gelcoat? i have no clue as how to do this properly. i dont mind spending extra to use marine products as that is the right way to do it. unless automotive paint can be used or it doesnt matter?
if someone could just lay out the process from start to finish it would be a huge help. ive read through restoration projects but havent found detailed outlined steps.
Thanks for your help. i attached pictures i think? im new to the forums at least posting to them. i can take more pictures if needed.
