JasonJ
- Joined
- Aug 20, 2001
- 4,163
After two days of mind numbing, hideously dusty grinding with the trusty ol' 4.5 inch angle grinder, the hull is now ready for the glasswork to begin. I have purchased the wood. I am using one piece of 3/4 acx and one piece of 5/8 acx with a layer of glass in between for the transom. It will then be glassed in to form the final 1.5 inch transom thickness that the splashwell will allow. the two sheets will also be screwed together with 1.25 inch stainless screws. The original transom was a miniscule 1 inch thick, kind of surprising for a 140 max horsepower boat, so my transom should work fine. The stringers will also be 3/4 acx. Floor will be 1/2 inch acx, screwed on with 1.25 stainless screws and glassed. Cost of all wood was $130. I know some on here do not care for acx, but it doesn't make a rip. Old boats were not made with marine ply, nor was it even as good as acx, but they still lasted for over 30 years. Doesn't take rocket science. Water soaks into wood and expands, doesn't matter if its marine ply or acx or solid or whatever. Its not what you make it out of, its how you care for it. <br /><br />
