Want to repaint my hull on an older Tuffy Bass boat. Minor glass repairs needed which I am good at (Former NHRA racer/mechanic, fixed way too much glass in my days!) The problem is what I know about painting and a dollar will get you a cup of coffee.<br /><br />The boat only is used in fresh water. Tri-Hull is structurely sound and only has minor scrapes and scratches. The problem is a lot of them. Is there a primer to be used first on fiberglass? What marine paint should I be using? Can it be applied with a brush? Is there a top coat to be used? How much must be sanded off first, in other words, down to the glass? It looks to have been repainted a couple of times with other removing the old paint. I plan on keeping it simple. <br /><br />Is there a special paint to use on fiberglass decking also? Repainting the flat deck is planned and not sure if I can use the same paint as on the hull.<br /><br />I work for a Ford Dealer (Business Manager)and can bribe the bodyshop to spray for me if it is needed. Just I enjoy working on the boat myself. Any help would be greatly appreciated!
