Hull repair hitting underside on boat ramp
yaltasydney
Had a bit of an amateur day on the ramp the other day and cutting a long story short, took a chunk out of the bottom of the stern. Basically any ideas or warning when attempting a repair of this sort. Pictures may illustate stupidi!
Woodonglass
Re: Hull repair hitting underside on boat ramp
Is this on the Stern of the boat? Is that your Drain Plug in the pic? More details please!
island mike
Yes I think its the stern too,Whereever its situated though it does not look bad.hardly a chunk.
Can be very easily fixed.
cosmetics..
boatnut74
Looks like it's at the stern right on the keel. You can see a roller on each side. Looks more like a basic gel repair to me.
oops!
hi.
welcome to iboats !
ya dragged it eh?
no worries.
look in the link in my sig.
get the recepy for oops sooper dooper structural peanut butter.
grind the area,,, clean with acetone, fill the area with the peanut butter.......then ad 2 layers of 1.5 csm over top....
the gellcoat repair as normal
cheers
oops
island mike
:D:D:LOL!!!!
I thought you were well on you way on vacation already!!
YOU should worry about your own stern as we speak!!!!!!!!!!!!!!!!!!
.:D:D:D::facepalm:
Sorry,man ! I could not help myself!!
Regards i mike
yaltasydney
Yeah sorry; its the stern on the keel with bung plug above. Chunk about 8-10mm at the deepest not sure if it has breached through tho. Should I be re-glassing or something else?
Cheers for the help
yaltasydney
Hey hotrod, not sure if water is from inside hull, took photos when it was still wet after use. What if it is water from inside? Am I to do something specific in this case? Any suggestions would be much appreciated - otherwise will just try oops soopa peanut butter recipe sounds like it might do the job :)
Woodonglass
The repair area must be totally dry before any repairs can be made. If the glass is saturated with water from the inside and if you have saturated foam on the inside then that's a whole different kettle of fish. If NOT, then OOPS, repair will do the trick just fine.
yaltasydney
Think hull is pretty dry now after 2 weeks of good weather so will start sanding back and preparing surface for application of oops! Peanut Butter recipe. Any other pointers out there regarding this kind of fix? See photos for more detail now its dry.
yaltasydney
oops!
hang on bud......if the hull was dripping for two weeks......the foam is wet.....more to do.....like woodie said
the repair will work fine..but you will still trap more water in the hull.
on second thought .......lol.......maybe just repair it and forget about it.... much easyer....lol
yaltasydney
Water has been drying for two weeks not been dripping for two weeks - photos with water dripping were taken when boat was washed down after ramp stuff up. Have put water thru bung and nothing seeped out of damaged area from what I could see. Will try post more photo's if possible. Oops! found someone on ebay who sells the milled fiber - AU$27 for 1kg - does that round right?
Thanx
yaltasydney
yaltasydney
Photo's I think
Woodonglass
Looks good and dry. Not sure on the price of your milled fibers, here in the states it sells for about $6 bucks a pound. A pound will be more than you'll need for this repair.
yaltasydney
Wow that's cheap - pretty much triple the price in Oz. Thanx for all the info and pointers all very much appreciated - maybe one day I'll be able to offer some helpful advice! :$
yaltasydney
yaltasydney
Have filled area with peanut butter and got it as best I can, see photo. From here was wondering what to do now to finish off - do I gelcoat or flowcoat from here and should I be putting a layer of fiberglass before this?
Thanks again for any help
yaltasydney
oops!
glass over all fillers..... 2 layers of 1.5 csm....
you have a ridge under your keel......you will want to make that flat.....either by adding more filler and building up the ridge line or grinding down the edge....
if you leave it .....it will create an air pocket just in front of the prop.
