Ski'nBlind
- Joined
- Jun 20, 2010
- 32
Allright, I got my 1 month old stator removed from the engine tonight ready to ship it back to CDI with the RMA number. Didn't take long to figure out why one of my high speed windings was "open". The bundled wires coming out of the starter was hitting the bottom of the flywheel and rubbed through the insulation and some of the conductors. My bad for calling out a part defective with only a meter. The wire bundle was hugging the block as tight as it would and my wiring was routed thru the original wire holders. This may or may not be a warranty item. There is no physical way (without fabbing a bracket) to hold that wire bundle closer to the engine. It appears the CDI wire bundle portrudes out and away from the stator at a 45 deg angle instead of straight down like the original. I would describe it as wrapped and shellaced where that bundle comes out of the stator so forcing it is going to make a "cracking" sound.
If it's under warranty I assume I would get an exact replacement and I will have the same issue. If it's not warranty-able should I buy a Sierra brand stator and hope for a better placement of the wire bundle. What do you guys think? Suppose I should call CDI tech support before I return it and see what they say?
